Any suggestions which cylinder head I should buy for stock engine? How much compression original crank shaft can take? Some high compression cylinder heads are available. Has anyone tried them?
This is what I have in mind at the moment: http://www.sip-scootershop.com/en/products/cylinder+head+mmw+px200+for_13013935
@scooterist avatar
@scooterist avatar
I would stick with the original piaggio one unless you plan on doing a cylinder kit and changing the compression ratio and all of that. The stock can be had very cheap(used)
nothing at all
nothing at all
The compression ratios available are way to high on that head. You'll just keep chasing down dragons with that.
You'll take away from the charm of the p200 class which is its bullet proof-ness and abilities to take a licken and keep on ticken.
Is 10,5:1 a lot, or too much? Originally compression ratio is only 8,8:1 which is not much I think.
nothing at all
nothing at all
Those heads go up to 12 to 1.
Im just sayin they are made for specific builds. You don't wanna just go slappin high compression heads on stock motors....but its your money so go ahead.
The example I gave is made for stock engine, and claimed compression ratio is 10,5 to 1. It comes with O-ring which would be good.
Usually increasing compression ratio is one of the easiest way to improve performance. Why not with Vespa, if crankshaft can handle more pressure.
@aviator47 avatar
@aviator47 avatar
Feel free to ignore jimmyb and scooterist. However,
I would consider contacting SIP and ask why they clearly state, "FOR RACE USE ONLY", in RED, for the head you linked. There might just be a reason for that warning.
Then, as jimmyb said:"but its your money so go ahead".
Why that attitude? I was asking experiences about cylinder heads if someone has already tried. If not, I could try it anyway.
Also Malossi 210cc "sport 2013" is "For race use only". Just like many other tuning parts are. In many countries it's not allowed to tune engines for traffic use. Kind of liability clause.
@mr10 avatar
150 GLx, Rally 200
@mr10 avatar
150 GLx, Rally 200
Dunno if shipping costs from the Netherlands are doable, but I've got a few origal p200 heads for sale.
@ginch avatar
@ginch avatar
I understand why you made the comment and agree in this case, however the reason they have the warnings is that they are not TUV-approved and therefore not road legal in Germany.
Thanks. I'll keep that in mind. But I'm looking for high compression head actually. I'm not sure if it's the right term but that's how it translates from my language.
@aviator47 avatar
@aviator47 avatar
Hadn't thought of that. Thanks. No such limitations here. I learn something very day.
nothing at all
nothing at all
I thought it was more a item "disclaimer" so if you screw something up with their head its your fault.
@aviator47 avatar
@aviator47 avatar
jimmy-
Just for chuckles, I looked at the listing for the SIP Road exhaust, and it has the same disclaimer. I would guess that such parts are not certified for EU (or German) environmental standards. I know that Mrs Av's old LeoVince had a certification label.
@scooterraton avatar
2 - Many
2 - Many
Yeah I worked with a guy from Germany. As he explained parts on vehicles must be replaced with OEM down to the tires. Pretty much any aftermarket part is labeled for race or off road use so it can be sold.
@aviator47 avatar
@aviator47 avatar
Before anyone can really answer your questions, we would need to know exactly what "performance improvement" are you seeking? Top speed? Low end or mid-range torque? Have you ridden the scooter enough to determine the performance deficiencies you are concerned with?
Any "performance parts" can be installed on any engine, but as jimmyb and scooterist are suggesting, simply installing a "performance head" is really a partial job.
As to the crankshaft handling the increased compression, the forces of the compression stroke are minor compared to the forces of the power (combustion) stroke. Or are you asking about the power stroke and not sure how to express that?
I am guessing you want to take advantage of the Winter to do everything possible to avoid loss of riding time come warmer weather, and I sympathize with that. However, I would strongly suggest you determine what "performance improvements" you want in terms of performance parameters (speed, torque, power band), and then determine the parts necessary to achieve those parameters. For example, I found my PX150 a bit short of torque on our mountain roads. My local Vespa technician recommended I try the SIP-Road exhaust for that specific need, and that solved it. And since the stock exhaust needed replacement anyway, for just a few extra Euro. Also got a bit of top speed improvement, but can rarely use that safely on the roads here. Not much in the way of straight runs.
So, might I suggest you restate your question in terms of desired improvement in speed, torque, etc, and then let folks with serious "performance improvement" experience suggest solutions.
px200
px200
Hello
The TUV and vehicle certification can make changes difficult, if you follow the rules as a religion, you cannot change anything that was not present at the the time of certification.
So you cannot change the vehicle colour or the type of oil it is supplied with, nor can you add anything like racks etc, however it is not policed except for the exhaust if that is marked not for road use it is an MOT fail, if it is not marked it is down to the discretion of the tester (and the copper that stops you for excessive noise) europe has given us so much over the years.
It is enough to make you
Grumpy
Fiddling things is my hobby at this moment. I have Gts which I Ride, this PX is for fiddling.
Malossi cylinder kit gives 2hp more without porting, I've been told. I don't want to do any portings for this original engine. So why not to try high compression cylinder head for 100EUR instead of buying 400EUR cylinder kit. As times goes by I could buy another engine which I could tune more. Do some porting to match with Malossi cylinder kit.
Increasing compression ratio should give more power, but not disturb nature of the engine. So it should give more performance and engine's nature remains the same. Basic rules, isn't it?
[ Time: 0.0154s ][ Queries: 3 (0.0043s) ][ live ][ 313 ][ ThingOne ]
