Im building a px engine at the moment.
Things you will need:
Tools,
flywheel pull tool
clutch nut tool
flywheel holder,
clutch holder
crank removal tool (homemade will do)
clutch compressor (homemade will do)
circlip pliers (2 sizes maybe need)-use GOOD ones not the crappy 3 in 1's
Socket set including 19mm socket
lttle ziplock plastic bags and a vivid marker
possibly a torque wrench
Good case gaskets(dont forget to replace the kick start o ring)
including the clutch cover o ring
and carb gaskets
these 3 things are bought seperately
new woodruff key for flywheel (buy 2)
New crank seals- get the metal corteco type rather than the cheap rubber ones
plastic carb petrol filter thing
kick start rubber buffers
new oil and petrol hose
at least, rear brake pads
30 weight oil for gear box
2T for oil tank
a little pottle of plain grease
new cruciform- buy quality piaggio, ensure your selector rod has the spacer washer on the end, if not buy one too.
Things you may need
red loctight
can of crc carb cleaner
can of gasket stripper (or wood paint stripper will do) and some yellow goldilox gloves + PLASTIC scraper
a little wire brush set from the 2 dollar shop + a strong toothbrush-for scrubbing
Spring removal tool
After inspection you
may also need
Kickstart layshaft gear
Rubber bushings for the cases and the rear top mount
carb box rubber if yours is split
a new stator or stator rewired if the wires are frayed where they pass through the stator
new spark plug
a new crankshaft and bearings for the crank(and bearing distance gauge)
new small end bearing
piston rings
new engine seals throughout (and possibly bearings for that matter)
woodruff key for clutch
clutch plates
clutch washer
bronze bush
and bronze clutch piston and plate
Tab washers-
input shaft
new exhaust
shims for your gears to engage properly
Tools(sockets, drifts, etc) to put the bearings and seals in-easier if a shop does this for you
cables
Someone to help set the timing with a strobe light once built and a TDC tool if required
It can be difficult or niggly if youve never done it before to remove the selector box or get the cases apart. ABSOLUTELY resist using screw drivers or pry bars between the faces to lever these apart.
Join a scooter club and someone there will help you as in real life help. They will most likely have the specialist tools for removal as well.
I think thats it
Cheers
