@kittysaz avatar
White GTS125 - Milo - 2009-2012 Red GTS Super 300 - Watson - 2012 - 2014. Silver Vespa GTS 250 - Carter - 2014
@kittysaz avatar
Hello all!
My switch to open my seat isn't working... It doesn't click or anything when I press it
I'm able to open the seat via the glovebox
Please can anyone help?
Thank you
Kit x
@gtdespatchcourier avatar
GTS 300ie
GTS 300ie
Rusty contacts on the switch. Try pushing the switch a few hundred times with the power off, this will clean the contacts.
@bommes avatar
GTS 250 a.b.s.
@bommes avatar
GTS 250 a.b.s.
Or open it up and clean it with a bit of sandingpaper and grease with some contact-spray.
You can pull the front of the switch out.
@roadster avatar
Kymco AK550
@roadster avatar
Kymco AK550
Re: Seat switch not working
Kittysaz wrote:
Hello all!
Thank you
Kit x
If it is the switch a good dousing in WD40 might help. I'm not familiar with this particular model so I'm not sure how easily you can get it out of its housing. Obviously if its easy to get out or get behind then you can bridge the contacts in order to prove that it is or is not a the switch which is the cause.
Regards Roadster
@bommes avatar
GTS 250 a.b.s.
@bommes avatar
GTS 250 a.b.s.
WD-40 is more solvent then anything else I wouldn't recommend using it on something other then removing tar or grease from your painted parts.
And the other component (although a very minimum part of it) in WD-40 is grease and that will act as an isolater.
Or some meant to be contact spray if you need to spray something into there.
@kittysaz avatar
@kittysaz avatar
Thanks all!
Wd40 all I have
I just did what you said and it worked!
Thanks so much and a very merry Chrissy from me and Watson xxxx
It might be a good idea to order a new switch next time you get parts. They are fairly cheap, and easy to replace, and they do wear out. The round switch for the horn, starter and seat on some models are interchangeable, so if you find a deal on any of these, they will work.
[ Time: 0.0089s ][ Queries: 3 (0.0017s) ][ live ][ 335 ][ ThingOne ]
