Hi all
I'm planning to cut down my GIVI screen and have read various posts on the subject - mainly those by Kruella_DV and Greg. As a result of my readings I have purchased a fret saw, painters tape and some non permanent markers.
Regards to removing screen. I'm nervous that if I do it wrong the conical nuts will fall inside the handlebar area so......
Do I just remove the four screws on the stalks? Is that all I need to do? Is there anything to watch out for?
Finally, with regard to finishing off the screen - would ANY sanding block do the job or should I splash out on the Perma-Grit block?
Merry Christmas one and all!
Dan
