@tolivercrash avatar
2012 Vespa GTS300 Super
If you have a GTS with the rear fold-down rack you'll notice that there are several small rubber plugs that fill in holes in the bars. (I'm not talking about the three "bumpers" that keep the rack pieces from hitting each other.)
I recently had the rear rack powder-coated and had to remove those rubber plugs. Some survived, but most ripped when pulling them out of the holes. I assume they're in place to keep moisture from collecting inside the tubes. But considering that some water came out when I removed them, I don't know how good of a job they do. I'm in Florida near the ocean so everything is always wet anyway.
Should I replug those holes and what would make a good substitute for the original rubber inserts? They don't show up in the parts catalog. Should I use a sealant or silicone and be done with it?
@gee-bee avatar
GTS 300
@gee-bee avatar
GTS 300
Silicone Plugs
I answered the question with a pm
@max6200 avatar
2006 GTS 250
@max6200 avatar
2006 GTS 250
i personally do not worry about them
as long as they are facing down
@wobbly_wheels avatar
GTS Super Black 2011
What did the pm say??? I could do with plugging mine....
@brown_beret7 avatar
1975 Vespa GTR 125, 1976 Vespa V90 (Resto), 2001 Vespa ET4 125 (Sold), 2009 Vespa GTS300 Super
IIRC and I'm thinking of the right holes, they're threaded, so I originally cut down some matched threaded screw head bolts (M8?) to keep these holds covered. I was mainly concerned about water getting into the bar and rusting. Then I found I could order the OEM part in the UK from AJ Sutton (VespaSpares), so I got a few when I ordered a few other spares...
They're shown as 'Saddle Handle Plug' on this page:
http://www.vespaspares.co.uk/genuineparts/2234/02.19/vespa%20gts300%20ie%20super/rear%20luggage%20rack?uid=0
The part number doesn't come up on the web page, but if you could get it you should be able to order them from any Piaggio dealer.
They're not rubber, they're plastic with a chrome effect finish.
Hope this helps
I know exactly what you're referring to and its not the rubber plugs I'm talking about.
Suggested visiting caplugs website for samples.
[ Time: 0.0107s ][ Queries: 3 (0.0031s) ][ live ][ 334 ][ ThingOne ]
