"Finally, when reassembling the clutch you must make sure that the circlip ends are both located in one of the inner basket grooves and not in the gap or your clutch can and will come apart when you least expect it."
I am certain I left the gap in the open, not under a basket tab. Do I need to go back in and fix it? I'm thinking I have to. Ugh. I'm pretty sure I made this mistake on the Lambretta once. It came apart.
At least I can use the 32mm socket and not take the clutch out to free the ring enough to turn it. Is it possible to remove the cover without removing the backing plate? I just need to tweak this. $&%^%&*\
edited title - it's no longer a question I know I have to go back in there damn it...
⚠️ Last edited by sdjohn on UTC; edited 1 time
