GTV 300. 2013
GTV 300. 2013
Hey,
Just picked up a new GTV 300 for Christmas. I'm looking for some advice on a reliable motorcycle carrier. I've seen some that attach to the trailer hitch, not sure which one is better. I drive a VW Tourage.
Any suggestions? What about weight?
@capt_gary avatar
2010 Vespa super,2016 vespa 3 00 1979 p200 with sidecar 1958 cu shman eagle with sidecar Inder trai ler 1983 bajaj tuk tuk tristar 2018 royal Enfi
@capt_gary avatar
Versa hauler
Only the best will do the Versa hauler is hands down the very best I hauled one 2500 miles and never adjusted a strap. I also used jettin industries bar ends for the front straps. Capt. Gary Kinney
@dailyrider28465 avatar
Mia Dolce II 2017 GTV 300, Ragazzo Vespa 946, Il Pazzo BV 350, & Mia Dolce GTV 250 -sold-
A cursory Google search...
Shows maximum tongue weight of either 660 or 770 pounds. In either case,you should be OK with a loaded GTV 300 at less than 400 pounds. But check your Toureg manual to be certain before you proceed.
07 LX50
07 LX50
Hitch carriers
This is the last thread on this subject and there's more threads before this one.
If your car will haul it,have fun!
@dooglas avatar
@dooglas avatar
Perhaps a VW Touareg?
@hernesage avatar
'13 BV350 Black
@hernesage avatar
'13 BV350 Black
The nicer ones have a way to stabilize the carrier at the hitch to keep the load from tilting. I would not get one without it. Even a slight amount of play at the hitch receiver results in a significant amount of movement side-to-side as the carrier "twists" in the receiver. Side-to-side refers to the sides of the hauling vehicle.
@syd avatar
GTS300 Super (Heinz) GTS250 Super (Bulger)
@syd avatar
I have a MotoTote with that exact feature. When bolted on the carrier does not move at all. But it is steel, so heavy, and requires a Class III or IV hitch.
⬆️    About 28 days elapsed    ⬇️
@ducatiss avatar
@ducatiss avatar
Re: Versa hauler
I want to second Capt. Gary's recommendation. We took a Grapes of Wrath trip to LA from Atlanta over Christmas with the GTS and Fly 150 on a double Versahaul mounted on the back of an Ancient Class C motorhome. I used Canyon Dancer handlebar tie-downs on the scooter's front and soft loops on the rear. No movement, no damage.
@chaco avatar
2010 GTS 300 i.e.
@chaco avatar
2010 GTS 300 i.e.
I have a Tilt-a-Rack that I use on the receiver hitch of an F-250 pickup. It is stable and relatively easy for one person to get the scooter on. It is aluminum and hence relatively light. It came with all the tie downs and needed no adjustments on several trips.
@tomjasz avatar
Grievance Farmer
Grievance Farmer
@tomjasz avatar
Well yes, you could hang a Yugo on that sucker.
@capt_gary avatar
@capt_gary avatar
Condor chock for front wheel
On my versa hauler I have made a upgraded mod to the front wheel stop by adding a Condor wheel chock to my versa hauler so that the scooter can be loaded by one person this is a worth while project. Capt. Gary
@ducatiss avatar
@ducatiss avatar
Re: Condor chock for front wheel
That is a great idea. Thanks.
[ Time: 0.0332s ][ Queries: 4 (0.0183s) ][ live ][ 313 ][ ThingOne ]
