I am thinking there is no way my P200 can power my nifty new 90 watt heated jacket liner. The headlight isn't that bright and I believe it is a mere 35 watts.
Does anyone know a P200s charging output to satisfy my curiosity?
![]() 1980 p200e, 2005 Stella w/ Sidecar, 2006 Triumph Scrambler
Posts: 428 Location: Chicago |
Does anyone know a P200s charging output to satisfy my curiosity? |
You mean to power your jacket off AC?
Make sure you paint some eyes on the back of your helmet so a mountain lion doesn't attack you while you are riding through the mountains. |
You only have ~85W to work with, about 50W on the battery side. The turn signals alone draw about 50W but they are only on part of the time.
I'd not try and run an accessory continuously that draws more than about 25W.
Positive
RIP
![]() T5s
Posts: 17005 Location: The West Of Yorkshire ... Gods Country |
raaaaaargh
id check that too .... most heated stuff ive looked at says dont use rechargables due to the slow drain or summat .... gave up n stay cold now
![]() UTC
Posts: 5109 Location: west aus |
![]() px200 cutdown,px180,px150. Puch SR. Puch scooterette
SFvsr wrote: You mean to power your jacket off AC? Make sure you paint some eyes on the back of your helmet so a mountain lion doesn't attack you while you are riding through the mountains. ![]() |
First Gear/Warmn Safe Jacket Liner and Batteries
T5bitza69 wrote: id check that too .... most heated stuff ive looked at says dont use rechargables due to the slow drain or summat .... gave up n stay cold now The jacket rocks, I've used it a couple times on my Triumph (hardwired). The draw is pretty hard, I have to turn the jacket off to run the starter effectively. I was pretty sure the Vespa couldn't run it, but was interested in how much electrical output we do generate. Huge tip: First Gear has contracted with WarmnSafe to make these jackets. The two companies sell almost all the stuff for the same price, except the batteries. WarmnSafe sells the batteries for about half what a First Gear dealer offers them for. I ordered two batteries, but bought the GF a jacket too. For longer rides we will probably need two batteries each. http://www.warmnsafe.com/ |
RIP
![]() T5s
Whew you are going to need it. -5 to -10 F in Chicago tonight. Thats -20 to -23 c for the the rest of ya.
Bottom line is heat takes power and heating elements draw a lot.
Try an LED jacket warmer. ![]() |
RIP
![]() T5s
