Vespa 125 VNB1
Vespa 125 VNB1
HI
I am considering installing a tuning kit on my Vespa 125 VNB 1960 mod (2 ports). Is there anyone who can give me some advice on which set I should choose. Malossi 166, DR 177, Polini 177 or Pinasco 177?
I want a strong scooter that makes about 100 km / h Which setup is recommended
- Tor Arne
@subetherbass avatar
Malossi 166 for th 2-port
1961 vbb and 1981 p125x
From what Ive read, not done with a two port engine there is Not a lot you can do without moding the engine case. I think there is a 166 two port kit. Or you could put a 150 vbb top end on it. However if you really want to tune it you will need to add a third port.
@speed_kills avatar
Mostly Lambrettisti
@speed_kills avatar
Mostly Lambrettisti
Without any hesitation I would do the Pinasco 177. Great kit and does not seize up easily like the Polini. Second choice, the Malossi.
[ Time: 0.0123s ][ Queries: 3 (0.0067s) ][ live ][ 313 ][ ThingOne ]
