Complete engine M200 (Air)
Complete Engine M200 (fully assembled with new parts) for smallframe vespa 200cc air-cooled. Lamellar intake on the cylinder, diameter 67mm, nikasil aluminum, forged piston two bands 67mm diameter. Crankcase and crankshaft QUATTRINI dedicated to shoulder full 9048 89.5mm diameter, 116mm long molded rod, piston pin 16mm, 56.5mm stroke, vespatronik ignition with variable advance request from 1kg and 1.5kg, 4 disc reinforced clutch bell 27/69 with flexible billet (optional pinion 28 teeth), 4-speed gearbox as the original Crown race material and hardening that allow a long-term (even with a lot of power), dedicated silenced muffler expansion that allows the engine to develop a great performance with very low noise. To be mounted with wheel 3.50/10. No need to cut the tray, even on frames wasp et3 spring. Dellorto VHSB d.34mm already calibrated or at the request Dellorto d.26 VHST. Heavy duty motor that has a lot of power down at low revs, which allows you to mount even with very long. Especially suitable for endurance.
http://zirriangelocorseinvespa.it/motore_M200.html
http://zirriangelocorseinvespa.it/Carter.html
This is why you should keep your dog on a leash...
I may have just messed my pants.
