@scootscott avatar
@scootscott avatar
Hello,
maybe a question for the experts as I am not. I know it is possible to swap out quadrants in a p200 engine for the true look of having the same kick start lever....but when dropping in a p200 engine in a ss180 or gs160, to keep that tire and rim stock, can you substitute a driveshaft from either of those models into the p200 case as to run the original hub, etc..?
if possible, of course the seals would be different as original , but assuming so, use the proper ones accordingly that accompany the installed item.
thanks
@fastfrog avatar
PX125,200, T5, SS180,TS125 and some more...
@fastfrog avatar
I guess not. Driveshaft is specific to each engine. Gearbox is way different....
Engine width is also different that why rims are different too.... If you want to use a SS/GS kick use the T5 kickshaft...
[ Time: 0.0099s ][ Queries: 3 (0.0037s) ][ live ][ 334 ][ ThingOne ]
