2013 icebear Maddog 50cc
I recently change my 50cc to a 100cc head and pistons, my problem is it will start and idle fine, if I give it some gase at idle it will bog and die. When I get it up to speed it will do 50 for about 2-3 mins and totally loose power and shut off, if I try to give it gas as it is dieing it will bog, so I just let it die wait a minute then it will start back and the whole process starts over again, I have look for air intake leaks loose wires,
@masala avatar
@masala avatar
946
Wish I could be of some help, but I know absolutely nothing about icebear Maddog 50s...
@tor2ga avatar
@tor2ga avatar
I suggest you go to the Icebear Maddog 50 forum site for info.
You doubled the cylinder displacement? Did you double the size of the carb? Did you double the flow capacity of the pipe? No? OK
Re: Need some help please,,,
Hustlin_Mel wrote:
I recently change my 50cc to a 100cc head and pistons,,
How many pistons? Soun like it crank, but it don't stay cranked. Y'all need to post this on modernbuddy, they use the same motor as chinese mopads and can help you a hole lot.
[ Time: 0.0120s ][ Queries: 3 (0.0014s) ][ live ][ 334 ][ ThingOne ]
