I got a new ignition switch for my gts 250 only to find the old switch didn't want to be replaced.
Seems it should be an easy emplacement, unplug and pull out, then install the new switch...looks straight forward. Well the old one was stuck in the metal cylinder that houses the key cylinder and the switch. When I tried a little pressure it shattered leaving as a remainder the part that seats inside the metal cylinder flush with the edge,
That piece refuses to come out.
I was wondering how to remove the key cylinder from the metal housing so I might "tap" out the remaining plastic piece of the ignition switch...from the front?
Such a nice day to ride.
