VLB 1969 Vespa
VLB 1969 Vespa
Anybody wants to know how to fit a 12 Volt 55W lamp in to a VLB 1969 Vespa, headlight assembly I have the information, you need to be creative & think outside the square but it does work, lights are much brighter.
Contact me direct on pearceylrmp@optusnet.com.au
Vespa PX200
Vespa PX200
Re: Car Headlight Lamp on Vintage Vespa
Not entirely sure why anyone would want to do that.
Plenty of easy options around to convert to the more useful 60/55W H4 format.
@ginch avatar
@ginch avatar
55 watts is kind of on the high side as far as stator output isn't it?
I have been under the impression that car headlights are 'aimed' in one direction compared to m/c ones which are supposedly aimed straight ahead. I'm referring to the way the glass is cast or molded.
Vespa PX200
Vespa PX200
If the stators upgraded to late PX or LML spec then you've got 120w to play with. Plenty for 60/55w H4 (fitted as standard to those models in fact).
The lens (or reflector) on should dip the light to the left in Australia whether it's a car or a motorcycle. High beam is symmetrical.
@ginch avatar
@ginch avatar
Always with the information, you!
Thanks Terry.
@jsunstar avatar
07 GT200, Flip flops
@jsunstar avatar
would the higher wattage bulbs get too hot for the plastic housing and lens? (the P has plastic is why i ask)
@ginch avatar
@ginch avatar
When I put a halogen globe in the Super, I found out it had a plastic lens when it started running down the legshields...
VLB 1969 Vespa
VLB 1969 Vespa
Whoops sorry to mention you need the metal & glass type lens, & yes I have a 120W stator fitted, tried various methods & used a blue type halogen lamp, very bright even in bright sunlight it can be seen.
To get better focus on lamp, I removed the larger ring on the lamp & it moved forward by at least by 12m/m (This is where the creative part comes in) pushing the lamp further back into the headset to allow filament to use the full lens for distance.
@joshzingzing avatar
can you wire one pathfinder or maybe two to a vespatronic setup?
also my vb1 needs wiring up len Razz emoticon i just need to buy a switch and some pretty colour wires. and a top shelf bottle of something for your efforts if your keen to do the wiring
@ginch avatar
@ginch avatar
Interesting... so you're saying you have moved the bulb forward or back from it's normal position to allow a better focus?
And what regulator are you using with that Len?
VLB 1969 Vespa
VLB 1969 Vespa
Joshzingzing Will wire re-wire bike, no problem contact me direct on pearceylrmp@optusnet.com.au, Ginch,as for the regulator use I a standard five wire regulator (Only four terminals used), I have fitted a 120W stator the lights light up the night now, originally installed bulb the wrong way around wondered why street signs & trees were so bright !!!!!
@trojanmod avatar
P, VNB, VMA, VSE, P/Sprint Chopper
@trojanmod avatar
while i'm always a fan of some new and interesting stuff
this kind of sounds like someone not having access to the right parts and going "oh well i can make those KC lights at autozone work"
remember, farmer's bodge too.
VLB 1969 Vespa
VLB 1969 Vespa
Trojanmod.
I ride the scooter at night, some of the streets are crap as far as lighting goes, fine on the freeway, plus I am retired so I tend to experiment with things to improve & this lamp certainly give a better light (Blue type bulb)
pearcey
@ginch avatar
@ginch avatar
If he'd called it "Brighter Headlight" or "Headlight Upgrade" it wouldn't sound like a bodge at all. You wouldn't call a HID conversion a bodge... bet you could pick some up in autozone as well.
http://www.scootercentral.net/forums/viewtopic.php?p=70231#70231
@rufio avatar
borrowed time
@rufio avatar
borrowed time
One of my P's was upgraded to fit a regular car bulb. Plug and play. The PO installed it. From what I remember, there was no issue of plastics melting.
@ccsp03 avatar
Rally 180, TS 125, PX 150 and a lot of smallies
@ccsp03 avatar
http://www.elightbulbs.com/catalog_search_results.cfm?keywords=6260&search_filter_brand=Eiko
No need to mod anything. I have not tried it with a plastic headlight. Although I'd dose warm your hands on a cold night
@joep avatar
05 PX, 80P200, 63Li150, to many others
@joep avatar
for what its worth I'm running a 65w H4 in my P with a BGM 120w stator and a BGM regulator. Works great. I have not seen an H4 retrofit for a scoot that old but maybe you could fashion something using the reflector from a motorcycle headlight.
[ Time: 0.0159s ][ Queries: 3 (0.0053s) ][ live ][ 313 ][ ThingTwo ]
