Good evening,
For a while i was unable to determine what the issue was with my tilt-lock not disengaging whne throttle was applied. The scooter would restrict any power until I manually dissengaged the tilt lock by pressing the unlock switch twice.
Tonight I discovered that the wire was broken right where the wire comes up underneath the seat's hinge.
I am curious, have any of you replaced this wire? Do you know what gauge wire it is? Is it easy to find the other end of the wire so that I can solder it away from the bike?
I'm thinking I will buy a soldering kit and add a little bit of length to the wire so that it won't bend in the same place until failure again.
Thank you all.
