Certified Pre-owned 2009 Vespa S50
Color: Dragon Red
Miles: 139
The Vespa S features retro styling with a newly engineered four-stroke, four-valve single overhead cam engine - the most powerful 50 cubic centimeter four-stroke available on the market today.
Manufacturer: Vespa
Model Year: 2009
Model: S 50
Price: *$2,395.00
Color: Dragon Red
VIN #: 500499
Miles : 139
DIMENSIONS
Length: 70.9 in. (1,800 mm)
Width: 29.1 in. (740 mm)
Weight: 243 lbs. (110 kg)
Wheelbase : 50.4 in. (1,280 mm)
Seat Height: 30.9 in. (785 mm)
ENGINE & DRIVETRAIN
Engine: 1-cylinder, 4-stroke catalytic LEADER, single overhead camshaft (SOHC) with 2-valves
Horsepower: At Shaft: 11.7 CV (8.7 kW) at 7,750 rpm
Displacement: 49 cc
Bore x Stroke: 2.46 x 1.91 in. (62.8 x 48.6 mm)
Torque: 8.5 ft. lbs. (11.5 Nm) at 6,000 rpm
Fuel Tank Capacity: Unleaded, 91 min. octane, 2.3 gal. (8.6 l)
Ignition: Electric and kick start
Clutch: Automatic dry centrifugal with damper buffers
Cooling: Ram air with sound proof cover and integrated SAS (Secondary Air System)
Lubrication: Wet sump, 1,000 capacity, chain-driven lobe pump, intake and delivery filters
Transmission: CVT with torque slave
BRAKES/WHEELS/TIRES
Brakes
Front: 200 mm steel disc with hydraulic command
Rear: 110 mm drum with mechanical command
Tires
Tubeless
Front: 110/70 - 11 in.
Rear: 120/70 - 10 in.
OPERATIONAL
Maximum Speed: 39 mph (62 km/h)
Frame: Load-bearing steel chassis with welded structural supports
Suspension
Front: Single arm with helical spring and dual-effect hydraulic single shock absorber
Rear: Helical spring with adjustable 4-position preload and dual-effect hydraulic single shock absorber
Available at:
Vespa Hartford - Scooter Centrale
161 Woodford Ave
Plainville, CT 06062
Showroom hours
Tue 10a-6pm
Wed 10a-4p
Thu 10a-8p
Fri 10a-8p
Sat 10a-6p
Call 860-747-2552 or email for additional information
*Price does not include Documentation or Registration fees. CT residents will be required to pay CT State Sales Tax & Registration fees (if applicable)
⚠️ Last edited by Vespa Hartford on UTC; edited 3 times
