@battlebornscooterist avatar
BV-250
BV-250
Ok, so I got the bike lift, and I got the 24mm socket for the plug, and I changed the oil with no issues EXCEPT- I'm new to this oil filter thing, what is the MV choice of tool to remove the filter?
I searched and found a variety of tools, which one do the other BV-250 users prefer?
7mm Allen key...
@super-fly avatar
Vespa GTS300ie
@super-fly avatar
Vespa GTS300ie
I use what is called a "drag link socket" which is basically a large slotted screwdriver socket
Works well with the filters with the groove on end
BV-250
BV-250
Yep, that's the kind of filter I"m talking about. I'm pretty sure a 7mm key won't work.....
The 7mm key works very well - it's the only tool I've used for years on those filters.
You have to keep the short end pushed along the slot with one hand while you turn the long end with the other.
[ Time: 0.0111s ][ Queries: 3 (0.0041s) ][ live ][ 343 ][ ThingOne ]
