@ender avatar
Piaggio MP3 500 LT Business
@ender avatar
I was just looking at different spare parts for the MP3 on EBay and came across this...
"Piaggio MP3 Business LT 500 Motorcycle MAGNUM Dyno-Boost Motorcycle Performance Chip"
Seems interesting but do you think it works and is it worth the money?
$169.99
"We have the right Fuel programmer to your Bike motor to satisfy every need. Let us deliver you the most productive Bike ECU chip on the net. Backed by a long term experience we offer full Technical Customer Service all week round. Dyno-Boost Motorcycle Performance Chip is engineered to your specific Bike and does not impact the reliability and lifespan of your Piaggio. Our parts feature full warranty coverage. This Piaggio Fuel programmer will work with the system of your Bike to get more juice burning in your Bike engine and more kick out time at your fingertips. Enhance the torque today. If you take a look inside the engine bay and around the engine of your Bike, there are a lot of stuffs in it. However it is not a big deal to locate the IAT /MAF/ MAP Sensor of your Piaggio and install our ECU chip on your Bike motor. Dyno-Boost Motorcycle Performance Chip installs to this part and does its job through the Intake Air Temperature Sensor signal."
http://www.ebay.co.uk/itm/Dyno-Boost-Performance-Chip-Piaggio-GTS-LX-MP3-MP8-300-250-50-400-500-S-125-ie-/150786156347?pt=Motorcycles_Parts_Accessories&hash=item231b8e273b
What do you guys think?
@maksor avatar
Gilera Fuoco 500ie
@maksor avatar
Gilera Fuoco 500ie
well i can give you my bankaccount number will ship a horn for that amount will make sound to but no performance increase Razz emoticon
The only 2 that will work are the Powercomander and a Rapidbike III both will cost about 750,- Tuned in on a rolling road with 5 to 10 runs
@ender avatar
@ender avatar
Yes that's what I figured. A load of crap! Razz emoticon
And yes please give me your bank account number and while your at it your creditcard number and cvv code as well!
Btw, that horns sounds interesting is it gold plated?
@maksor avatar
Gilera Fuoco 500ie
@maksor avatar
Gilera Fuoco 500ie
got a spraycan with goldcolor paint somewhere Razz emoticon
I like the chart
generic dyno chart for a 100 hp normally aspirated engine.
But yet its for a mp3, hmmm the 500 is less than 45 hp so really folks who are you blowing smoke to. Even if they did a true test on a mp3 the gain would be what maybe 1hp if they are lucky. Hold on to your bars over that.
@ponydrvr avatar
Honda CTX 700D
@ponydrvr avatar
Honda CTX 700D
I came across these over two years ago when they cost less than $50 US. They didn't work then, not likely to work now.
I completely agree with Maksor.
@olestra avatar
2009 Piaggio mp3 500ie "Ephie"
@olestra avatar
I've seen these type around for a few years -- typically they wire in to the air intake sensors and skew the readings, making the vehicle run rich. They work okay (3-5% improvement) on a open-loop system that is turned lean to begin with.
For anything else... no results other than clogged catalytic converters and dead oxygen sensors.
For the seller, they are a great deal -- 1-2 $ of parts, sold for $100-200 dollars.
@klaborde avatar
@klaborde avatar
Not to take over the Thread...
But I have a question on the same line.
What about these devices that Mallosi and others sell that go between to override the Piaggio Computer. Suggested when you change your Exhaust... Is this also Questionable?
Here is an example Link of a Product.
http://scooterpartsco.com/index.php?main_page=product_info&cPath=108_109&products_id=801
Keith
@stickyfrog avatar
Moderatus Rana
MP3 250 and 2 MP3 500s
Moderatus Rana
@stickyfrog avatar
Performance Chips
@olestra avatar
@olestra avatar
Keith
looks like that is a bit of a different beast. It changes rev limitations, and emulates lambda sensor. Lambda sensor is the oxygen sensor, so this would change your bike from a closed loop system to an open loop system. It also contains mapping for non-stock crankshaft.
Makes sense if your setup has the malossi crank, or can't fit the oxygen sensor anymore.
probably would improve speed and power some, at the cost of more emissions and mileage.
My opinion of malossi is they don't sell snake oil. Up to the buyer if the cost of their stuff is a good value for the changes in performance. I haven't found any Malossi gear for my rides that the price/performance ratio matches my wants/budget.
MP3 500
MP3 500
Re: Performance Chips
stickyfrog wrote:
Uh?, I think that's performing chips
[ Time: 0.0174s ][ Queries: 3 (0.0031s) ][ live ][ 343 ][ ThingOne ]
