@boulty avatar
Moderator Australis
Moderator Australis
@boulty avatar
Has anyone cracked open the horncast or front leg shield on a Primavera?
I'm wondering if I should remove my Stebel Nautilus from the GT200 in preparation for my impending move to a new Primavera.
Cheers
@david_masse avatar
@david_masse avatar
It looks similar to the LX which compared to the GTS has a ton of room in the legshield.
Theres one in my LX.
Just sayin
@boulty avatar
Moderator Australis
Moderator Australis
@boulty avatar
Chur Bro 8)
@alexbv200 avatar
2015 Sprint 150 ABS Yellow. 1974 Vespa Rally 200 White, non battery model.
@alexbv200 avatar
Re: Stebel fit in a Primavera?
Cheers
We checked...
Does not look like the Nautilus will fit, and to get to it, you will most likely have to take apart the glove box.
⚠️ Last edited by AlexBv200 on UTC; edited 1 time
@dooglas avatar
GTS 300ABS, Buddy Kick 125
@dooglas avatar
The Steibel Magnum is nearly as loud and much more compact. Use one of them if the Nautilus won't fit.
Get the smallest one you can. I barely have room for my PIAA and the Primavera looks smaller than my LX. Jealous of your new scooter. What color?
@boulty avatar
Moderator Australis
Moderator Australis
@boulty avatar
Actually I have discovered the Primavera also has a much improved horn. Quite loud and a piercing tone. I might leave it a stock for now.
@knutte_i_amerika avatar
Montebianco Primavera, Subaru turbo with Vespa trans
I just used the horn for the first time....it was embarrasingly weak
[ Time: 0.0103s ][ Queries: 3 (0.0029s) ][ live ][ 342 ][ ThingOne ]
