Hello all, I've used lots of information from this website to sort out some issues with my girlfriends smallie and I'm hoping to find an answer for my newly aquired P200e.
Backstory: Unknown mileage on engine, etc. however the previous owner used to run the local scooter shop and everything appears legit and well done. It's been sitting off and on for about 4 years. Doesn't leak anything and has very little grime buildup.
When I first got it, the clutch pull was easy and shifting was effortless (to me it felt TOO effortless). The clutch needed adjusted as it would lurch and bog.
It would randomly come out of gear on hard acceleration. I wasn't able to figure out if I was pulling it out of gear because it moved so easy or it was doing it. This happened 5-6 times and it sounded terrible when it would slam back into another gear.
Currently: If I adjust the clutch so it engages and releases correctly the bike will pop out of every gear but 4th. If I set it back to how it was, the bike will pop in and out of 3rd and sometimes 1st. To me, these issues shouldn't be connected.
I've pulled the selector box and inspected it, reset the cables, greased everything. Gear oil is clean and full. I keep thinking cruciform replacement but the clutch part has me stumped.
Thanks.
