2009 250 GTS Super
2009 250 GTS Super
The high tech wrist watches with GPS built in them, what is the GPS for?
http://www.rei.com/product/867476/garmin-tactix-gps-multifunction-watch (here's one example)
Is it used to help you find your way? As in, can you start running in the middle of Manhattan to nowhere and then use the watch to help you get back home?
Or is it solely used for stats, like tracking your speed?
@aviator47 avatar
@aviator47 avatar
Read this.
It appears to be able to offer some form of navigation info, but from what I can glean, straight line nav, not roadway nav.
@caschnd1 avatar
Grumpy Biker
Grumpy Biker
@caschnd1 avatar
They use the GPS to measure how far you walk/run.
@aviator47 avatar
@aviator47 avatar
It appears to also give bearing and distance to a preloaded destination (waypoint) and stores your track for display on an external device.
@stickyfrog avatar
Moderatus Rana
MP3 250 and 2 MP3 500s
Moderatus Rana
@stickyfrog avatar
And it even tells time.
@syd avatar
@syd avatar
Re: NSR: What does the GPS in new sport wrist watches do?
It helps them find you when you are lost in bonkers.
@film_at_eleven avatar
LX 150
LX 150
It helps them keep track of you.
The gps is usually to record tracks and performance data (speed, distance, heart rate, elevation, grade etc etc etc etc etc). Essentially they gamify the activity. Sometimes they are helpful in navigation... A watch screen is a bit small to be very helpful here.
@stickyfrog avatar
Moderatus Rana
Moderatus Rana
@stickyfrog avatar
It does bro. Got my tinfoi...aluminium wrap on..
@aviator47 avatar
@aviator47 avatar
From what I can discern, it would be useful in overland navigation, as it has a magnetic compass, can give current location in Long and Lat, and will point in the direction of a waypoint you select, with distance to go info. Of course, it has no way of alerting you to obstacles in the straight line path it gives from your current position to your destination. Thus, if there was a lake between you and your desired destination, for example, you would have to establish waypoints before the fact to bypass the lake.
[ Time: 0.0193s ][ Queries: 3 (0.0072s) ][ live ][ 343 ][ ThingOne ]
