hi again!my analog koso rev counter,is only giving me x2000 revs instead of x1000!!!
the back buttons have 2 setings.the first is 1,2,3,4 and the second is 1,2.that is when you press both buttons together,and you choose the correct setting..
the only right' setting seams to be 1 and 1.
but even then,is showing me x2000.the other combo settings are just screwed up!!
i know its corect if you subtrack 1000revs.
i am used to it right now,BUT..now that i wat to put on a malosi cylinder,the revs are finished,even with the 28 carb on,it reaches 7000,which is 14000 on mine!!!
i have conected 1 cable to the on/of switch,one grounded ,i used to have one on the positive of the battery,but i found out that its working the same without it so i took it of,and the one thats attached to the spark plug lead.
anyone knows what the problem is?thanks,merci,spasiba,efxaristw!
