Vespa VNB & more
Vespa VNB & more
Bongiorno / Hi,
I have got a Vespa VNB /1965 that was beautifully restored by a professional some years ago and used little since.
Problem: It takes 5-6 hard kicks with full throttle to start.
It then 'spits petrol' when it finally starts.
Then it runs nicely. If the petrol switch is closed while standing, it starts faster.
I want this Vespa to run as perfectly as it looks and I do not want to have to close the pertrol switch every time I stop 2-3 minutes for a quick coffee or suchlike.
=> Reading other discussions, I suspect the float needle is the problem. Is it so?
=> Is this something I can relatively easily fix myself? or should i rather give it to a proffessional? (I would say I am technically skilled and I do have a workshop book, but I have never dismantled a carb, and I do not have too much spare time for extensive works these days).
Kind Regards
@vader19 avatar
Mr. Clean
P,SUPER,V90, 50 Special
Mr. Clean
@vader19 avatar
It very well may be the needle as you say.. that is pretty common..
... and YES! YOU can do it yourself..
Here is a link to some information on how to do it:
The section about the float and needle is at 1:30 of the 1st video.... but I suggest you watch the whole video..
Part 1:
Part 2:
Are you using the choke when starting with a cold engine?
Vespa VNB & more
Vespa VNB & more
Thanks a lot for ultra-fast response! Will study the videos and give it a try as soon as I am at my vacation home where that vespa is located.
Vespa VNB & more
Vespa VNB & more
.....yes CHOKE, but it seems to make no big difference. I have quite much experience with starting 2 strokes (mainly boat outborder) in all temperatures so I know quite well when and how much to choke. Here the described problem always occurrs when it stands for more than 5 minutes with the petrol switch open (cold, warm, 5 minutes, 5 days) wbr
[ Time: 0.0093s ][ Queries: 3 (0.0024s) ][ live ][ 343 ][ ThingOne ]
