Hi guys.... When I start my vespa and put on any indicators the front left or right will flash once only then stop working and the back indicator will just stay on all the time without blinking..... It is a px125 model with a p200 engine in it so will only run the lights extra when the engine is running.... All worked well until I had it out a good run yesterday then this happened, I have checked the switch and there are no loose wires and had the horn cover off incase anything came loose but all seems in order.... Any help would be great.
Thanks in advance..... Scott
