Hi all
I promised an old local vespa owner to help him with his Sprint 1965.
He told me that he was scared of riding it when i was cold. When he puts in 1. gear the front wheel kisses the skies, 2-4 is pretty ok. When it gets hot the problem nearly goes away. It does not slips out of any of the gears. He have turned the idle a little bit High because he is scared that it will die when he is holding still in the traffic.
I found out that the engine only had 2/3 Oil (or less) and the clutch wire was a little loose. I drained it for Oil and tighthen the clutch cable, it helped a bit.
I am thinking of changing the plates and springs in the clutch and give a new teflon clutch cable (cable is very old). If that does not do the trick i am thinking of changing the cruciform and proberly renew the gear selector box (original and looks like never changed).
What do you guys think of this?
Any Ideas ?
Cheers
Kasper
Denmark
