So I recently replaced my flywheel cover with new water pump bearings and all, new motobat, oil change, coolant flush ect. Everything went on fine until I noticed oil leaking inside the transfer case!
It might have been leaking prior due to failed water pump this past summer.
Has anyone DIY this job? If so do I need any special tools? I know I have to pick up a variator removal tool. The maintenance manual calls for a oil guard punch remover (part# 020622Y). Is this necessary?
I found all the parts needed
1. 847116 OEM Piaggio/Vespa Timing System Cover/Seal
2. BZ5442 Buzzetti Variator Locking Tool For 250, 300cc
3. Doing my rollers and belt as we'll 6400 miles total.
If anyone has attempted or completed this job please advise!
Currently the gts starts and runs with the oil leaking being an issue.
Thanks all
