Fuoco 500, MP3 125
Fuoco 500, MP3 125
Hi guys and gals,
got a 2007 MP3 125 with a carb not fuel injection,
took it apart to clean out the two year+ old fuel that was stuck in it lol
was wondering if anyone knows what the zero setting...readings
for the throttle position sensor is supposed to be?
cant see anything in workshop manual...but there is one part to do with idle adjust...
"after adjusting the idle speed, proceed with the TPS zero setting"
any ideas?
ta! Adam.
@drinu64 avatar
Gilera Fuoco / BMW R850R
@drinu64 avatar
i believe that a tps sensor is found on injected models only .. i stand to be corrected though
That was my first thought - but a glance at the circuit diagram shows there is indeed a throttle position sensor. Used to alter the timing of the spark presumably.
Fuoco 500, MP3 125
Fuoco 500, MP3 125
Deffo TPS attached to a carb and yeah it will be for CDI mapping and spark advance so I want to make it right as iv taken it off the carb
All I need is a low resistance value for when the throttle is closed a high value when fully open.
Get thee to a dealer, cross their palms with a good 'drink', and have them play with their Piaggio online tools, whatever is the flavour these days (PADS?).
You might get a remap of the CDI in the process. (I think that one is a FLASH unit, could be wrong though.)
Fuoco 500, MP3 125
Fuoco 500, MP3 125
Aye will have to save some penny's up then...I will have to post some results after they mess with it.
⬆️    About 11 years elapsed    ⬇️
Piaggio mp3 125 2007
Old thread but older mp3 do have a throttle position sensor, reset is easy , disconnect whilst ignition is on , turn off perhaps a battery disconnect, re power and turn on then plug into tps turn of then back on !
That's should work ! Most carb bikes had tps late 90s upto fi systems and if that didn't work copy for example the process for yam gas , it's the same process!
It should read Yamaha fzs 600 !sorry!
[ Time: 0.0106s ][ Queries: 3 (0.0047s) ][ live ][ 343 ][ ThingOne ]
