64 GL150, 64 VBB retired
The "dangle" being the fuel lever connected to a bgm fast flow. On a stock tap the angle is a strong 45 degrees from horizontal. The opening in the bgm that accepts the end of the lever and pin is a smaller diameter so it does not let the lever hang down as much, only about 20-25 degrees. In my case, in a GL frame, it's just enough that it won't clear the inside of the frame and feed into the lever opening. Anyone else find this out? I guess I could bend the lever slightly to make up the diff but want to see what others did.
Bent lever about 15 degrees at 2" from tap and tank slipped in just like it should...
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
Post a pic if you took one.
[ Time: 0.0110s ][ Queries: 3 (0.0022s) ][ live ][ 343 ][ ThingOne ]
