Hi guys
This part on my bike is pretty dull. Are there any household items that would help restore it to its former glory??
Hi guys
restore
try rubbing it with some real fine steel wool then seal it with some automotive wax. try just a little of the area first to make sure it will work, good luck.
eeeee bip
BMW GS 1200, Kymco Downtown 300, Honda SH125 Mode, Honda PC800
Posts: 23003 Location: South East Great England of Britishland |
Posts: 8758 Location: Annapolis, MD, USA |
It's not chrome; it's stainless steel. It'll never quite have the luster of good chrome plating, but any good stainless steel polish should get it to its full potential.
Re: restore
mikenpalsie wrote: try rubbing it with some real fine steel wool then seal it with some automotive wax. try just a little of the area first to make sure it will work, good luck. |
Posts: 23516 Location: Harriman, Tennessee, Tn |
STAY away from steel wool. that stuff will scratch the heck out of it.
semichrome polish or jewlers rouge will do wonders. |
MP3 500 (no - longer); 2008 Victory Vision (gone), 2012 Goldwing (gone), 2019 Wee-Strom (gone), 2024 Triumph Tiger 900 Rally Pro
Posts: 891 Location: Alpharetta, GA |
Use Flitz Polish. Absolutely the best stuff I have ever used. Polishes steel, chrome, jewelry, and even clears up the fogged headlights on old cars!
Posts: 12008 Location: Hermit Kingdom |
polish chrome
originally he said it was chrome plated, if it is stainless do not use steel wool, use a stainless polish or maybe a super fine rubbing compound.
Peugeot Citystar 200i, Vespa PX 200
Posts: 798 Location: Finland |
That scooter looks gorgeous. I would wait for aftermarket chrome heat shields for the Primavera.
RIP
T5s
Posts: 17005 Location: The West Of Yorkshire ... Gods Country |
tipster
a good rub down with a nice 800grit paper and a coat of satin black rattle can ........ better than new
Re: tipster
T5bitza69 wrote: a good rub down with a nice 800grit paper and a coat of satin black rattle can ........ better than new |
Polish
First try Mothers Chrome Polish and if that does not work you can always re-chrome the piece or buy a new replacement part if you can not live with the part not looking new. I would not use anything that would scratch the chrome plating. I have a 1967 Triumph TR4 A IRS and I either re-chromed many parts or bought a new piece through a vintage British car supplier. It depends on the price and sometimes the metal quality on an older piece is better than new reproductions so re-chroming was a better option. The photo you are showing does not look like an expense part to replace new.
⚠️ Last edited by Bart4u on UTC; edited 1 time
Posts: 1170 Location: Depends on where I happen to be. |
RIP
I got a new one for $30 over here. Now i can play around with the spare. Haven't a clue what they go for over there. Good luck.
Re: Polish
Bart4u wrote: First try Mothers Chrome Polish and if that does not work you can always re-chrome the piece or buy a new replacement part if you can not live with the part not looking new. I would not use anything that would scratch the chrome plating. I have a 1967 Triumph TR4 A IRS and I either re-chromed many parts or bought a new piece through a vintage British car supplier. It depends on the price and sometimes the metal quality on an older piece is better than new reproductions so re-chroming was a better option. The photo you are showing does not look like an expense part to replace new. |
Here is one dealer advertising the part as Chrome heat shield. I will call my local dealer tomorrow to do more research to find out the finish of the part. I personally believe it to be chrome and not stainless steel.
Induction System Aspirated Exhaust Description Black; Chrome heat shield Engine Description 150 Cooling Forced Air Maximum Power 9.5 kW Maximum Power RPM 7,750 Carburettor EFI - Electronic Fuel Injection (Port Injection) Engine Config Forward-Inclined Exhaust Config 1 Into 1 Engine Capacity 151 cc Maximum Torque 12.8 Nm Maximum Torque RPM 6,250 Engine Type Piston Engine Stroke 4 Bore 58 mm Maximum Speed 100 km/h Stroke 58.6 mm Cam Type SOHC Cylinders 1 Valves Per Cylinder 3 Lubrication Wet Sump |
[quote="Bart4u" I personally believe it to be chrome and not stainless steel.
[/quote]use a magnet |
A magnet is not always a true test. Stainless steel is an alloy that has different ratings. For example there is a big difference between 300 and 400 stainless steel one will stick to a magnet and the other will not. If you notice stainless steel kitchenware will stick to a magnet holding rack but the same magnet rack will not stick to a stainless steel kitchen sink. Stainless steel can also be chrome plated if the desire is to have a more shinny surface. I will do some more research to see if the part is chrome. The cost to re-chrome a part like that is about $50.00-70.00 so it might be cheaper to buy a new part.
Bart4u wrote: A magnet is not always a true test. Stainless steel is an alloy that has different ratings. For example there is a big difference between 300 and 400 stainless steel one will stick to a magnet and the other will not. If you notice stainless steel kitchenware will stick to a magnet holding rack but the same magnet rack will not stick to a stainless steel kitchen sink. Stainless steel can also be chrome plated if the desire is to have a more shinny surface. I will do some more research to see if the part is chrome. The cost to re-chrome a part like that is about $50.00-70.00 so it might be cheaper to buy a new part. Don't waste your time trying to prove yourself right. If you are so sure of yourself, though, why don't you take some steel wool to your own heat shield and see if it scratches? |
There seems to be a lot of confusion of what this part is made of. The manufacture calls the exhaust "Black, Chrome". Scooterwest originally told me it was chrome. Now they say it is stainless steel but they have always called the part a chrome exhaust shield. Sometimes you can polish out small scratches if the part is tripled chrome and not deep without discoloration as opposed to single chrome but I could be wrong about this part. The question is why does the manufacture specs call it chrome? Who knows.
Those are stainless. They've always been referred to as chrome by everyone, but the actual material is stainless.
