@kulezi avatar
1980 P125X, 1978 P200 in pieces, 93 150 Exclusive (RIP)
@kulezi avatar
Hi all, I'm looking in to getting a set of jets for the P200 I'll be working on this summer. Just want to make sure I get the correct one. BGM set 100-122 (I'm at around 5000 feet and up, so I figure I'll be sizing down a bit from the stock 116), and do I get the 6mm size or the 5mm size?
For the P125 the 75-98 set (I think the stock one in there is a 96), in the 6mm or the 5mm?
My P125 seems to be running ok for now, I'm just thinking ahead to a higher or lower altitude trip.
They are out of stock at the moment, but want to be notified when they are in...
Thanks!
78 P200 05 PX150
78 P200 05 PX150
Sounds like the right size range but these are the wrong kinda of main jets. The 5/6mm are for the Dellort PH/VH carbs. You want the jets for the Dellorto SI style carbs (assuming you have stock carbs.)
The correct style jets are these: http://www.sip-scootershop.com/en/products/jetting+kit+dellorto+105128+_40260000
Chuck
@willie_b avatar
@willie_b avatar
www.jet200.com and www.scooter-speed.com stock Dellorto SI carb main, pilot and atomizer jets.
@kulezi avatar
@kulezi avatar
Thanks!
Ah, I see now. So glad I asked and thank you for the replies. Looks like the best deal is to get two sets from BGM (90-112 and 115-138) it'll be the same price as the one from scooterspeed and a broader range of sizes. Should be able to get the correct jets for both my bikes...
[ Time: 0.0092s ][ Queries: 3 (0.0030s) ][ live ][ 343 ][ ThingOne ]
