Shoulda took notes or pics. I'm putting the headset back on and can't be sure on the routing of the harness from the frame through the headset.
I have the sheathing for the front brake switch wires and the sheathing for the large main harness coming out the frame on the throttle side.
I have the turn signal sheathing coming out the frame on the shifter side.
So far that is correct as I did not move those out of the frame.
There are 3 channels through the headset, shifter side, throttle side, and rear ( to the left of the headset bolt)
So there is the sheathing that goes to the front brake switch and that is obvious to me. It goes up to the right with the throttle cable. I think the main harness needs to go up that way too, and then the t/s harness goes up left of the headset bolt.
Or does the main harness go left of the headset bolt and the t/s harness goes up the shifter side channel with the gear and clutch cables?
Any help appreciated. I'll be searching in the mean time.
