@leslie_silver_24 avatar
2011 Vespa S150ie
2011 Vespa S150ie
I just pulled out my 2009's windshield and it appears to fit the 2011 150.. How do u know for sure?
@dooglas avatar
GTS 300ABS, Buddy Kick 125
@dooglas avatar
The headlight cutout for the GTS and LX are different as the position and size of the headlight is different. The upright brackets to mount the screen on the GTS and on the LX are also different as they are set at a different angle (again, because of the position of the headlight). I believe you could use the GTS plastic screen on an LX if you did not mind that the headlight cutout was too big and if you had the correct LX mounting brackets.
2011 Vespa S150ie
2011 Vespa S150ie
Thanks for the information-
[ Time: 0.0518s ][ Queries: 3 (0.0407s) ][ live ][ 343 ][ ThingOne ]
