I have a Sprint V (in P body). I split the cases, done seals, gaskets, cruciform, clutch rebuilt and replace 6v points stator with 12 electronic setup. Suprisingly it started after this as it was my first Vespa engine dropping and splitting experience. Quite easy thanks to a few how-to websites and this forum
From about 1/2 to WOT I experience something between too much gas/not enough air mix and maybe miss firing on intermittend strokes (that's the best I can do ). New plug is nice choclate brown. It was somewhat better on my first 5km trip, but when returning home and doing a chop, I realised I never fastened the plug, only screwed in by hand. So, I thought I need some more air in the mix, so I fiddled with the air/fuel mixture screw (originally at 1 1/2 turns out). Seems somewhat better at fully turned in, but plug gets a bit lightish brown...scared of running into seizes. But with screw turned in it is a PITA to start. 1 1/2 turns out, start on first kick.
Something that is concerning me since cleaning the carb is that my slow running/idle jet doesn't have a hole in the top for air flow, only bottom for fuel...wrong slow running jet??
Dell'Orto 20/20
Main Jet: 160 / BE3 / 100
Idle Jet: 50
So......is it bogging?
How do I fix it....whatever its called
Thanks!!
⚠️ Last edited by carelgrundlingh on UTC; edited 1 time
