I just rebuilt my motor, installing a new crank, carb, pipe, and pinasco 177 kit , seals and bearings etc.
I was going along at about 30 or 35 mph when I felt the motor begin to bog down so I immediately pulled the clutch, the engine died and I coasted to the side of the road. There was no shoulder and it was fairly busy so I just popped it in 3rd and restarted. I tried to get some fuel in the cylinder thinking I may have experienced a soft seize.
Made it home without any problems.
I took the jug off to take a look and to check the ring gap and everything looked fine so I put it back together and turned the motor over without the plug just to hear how it sounded. It felt like there was compression without the plug installed and didn't turn smoothly.
I think I found the problem. A bolt on one of the coils came loose and hit the inner flywheel. I should have used lock washers or thread lock when I rewired the stator.
