I'm having an issue with my 2005 ET4 with 8k miles on it. I was driving along and it suddenly had a loss of power and would not accelerate. I had to nurse it back home (thankfully it was downhill most of the way because I can barely get this thing to move).
It starts and idles perfectly fine but when I try to give it throttle it falls flat on it's face and will die. I am stumped as to what may be causing this.
Here is what has been done so far:
--Gas tank has been completely emptied and filled with fresh 91 (thought I may have gotten some bad gas).
--Changed the spark plug with brand new one.
--Cleaned and inspected the Carb removing all jets and making it look new again .....4 times so far
--Tried running it with the Brown key and the same thing happens. I also reprogrammed the Blue key and it runs the exact same way. The security light flashes when the key is off. Once the key is turned on it flashes once for 0.7 seconds then goes off and stays off.
--Unplugged every electrical connector and reconnected them.
--Checked all of the fuses.
--I bypassed the fuel tap with a gravity bottle full of gas.
--Cleaned the not very dirty Air Filter.
--Removed the muffler to test if the exhaust was plugged.
All of the tests above have resulted in NO CHANGE in the way the scooter runs. It still will not rev up past around 1500-2000 RPM. It idles perfectly fine and will probably idle all day long. I am going crazy over here trying to figure what the heck could be wrong with this baby !!!
Any help would be greatly appreciated.
