I have a VBC large frame...put a p200 engine in and sito plus...issue is the centre stand doesnt have enough clearance to go up...thought of a side stand to go on the exhaust port side but not sure if down pipe will be an issue with clearance or can i not use a sito plus made for a p200 with this frame? Finally do all side stands need new holes drilled into the floor board or can i use the two centre stand holes on the right?
Thanks in advance
Peter
