Have never seen it accumulate that fast so I opened the airbox and discovered that my air box mod plate had come loose. I guess there was a lot of oil built up and it came out when it loosened? I don't know. Anyway gotta fix it first.
After cleaning everything with a strong de-greaser I took off as much of the jb weld and the other stuff (can't remember what I used) that was sealing it as I could with a grinder. My plan now is to use a combination of things to secure it. I will use ABS adhesive and JB Weld to fill in gaps but plan to strengthen the whole thing with an aluminum strip I fabricated from a shelf bracket.
I used a small plastic boat cleat with the bottom cut off and trimmed to size for one side. And fortunately I left about 1/4 of the tube from the original on the other side to put a screw clip in. The pictures below will help see what I am talking about.
So looking for ideas, suggestions, comments on anything with this because I am just winging it.
