@mark1027 avatar
Rally200,VBB, SS50, V90 ,PGO, BlueBadgePrimavera
@mark1027 avatar
Does anyone make a long stroke crank for the early Rally 200 with the Femsa ignition?
@joshzingzing avatar
better off converting to Ducati for that sorta thing
@mark1027 avatar
@mark1027 avatar
That's what i was thinking. I haven't seen a long stroke for the original ignition. Curious if they exist.
So to use the p200 style crank I would need:
P200 long crank
P stator
P flywheel
Ducati CDI
12v reg
Fly bearing...T5?
Appropriate seal
I remember reading that the inside of the P stator needs to be modified to clear the cases. Anyone have experience with this?
⚠️ Last edited by mark1027 on UTC; edited 1 time
@mark1027 avatar
@mark1027 avatar
The engine is stock. Not interested in the the Vespatronic, I have one on another bike. Would rather find a crank that would work with the Femsa setup, or convert to the Ducati setup.
I had a P200 engine with a stock topend and a long stroke, and loved it. My rally needs a crank and the Femsa coil finally went out after 17 years. I have a P stator, CDI, and reg. so I'm half way there on parts if I go that route.
Does anyone have first hand experience with the Ducati conversion? Would like to know exactly what I need to go that way.
@willie_b avatar
@willie_b avatar
When building my long stroke Rally motor, I used a Vespatronic ignition. Considering the variable timing, this is a much better option for a built motor.
I'm half and half about that on a rally ....as Ducati is more reliable
@mark1027 avatar
@mark1027 avatar
Also the bike has no battery or turn signals. I will be making a new harness for it, so the wiring conversion is not a problem.
@sfvsr avatar
a lambretta or two
@sfvsr avatar
a lambretta or two
I've done this a bunch of times. I'm sending you a PM. I can then send you some pictures of what you need to do to the stator.
@mark1027 avatar
@mark1027 avatar
Got it, thanks!
@nebulae avatar
Vespa Rally 210
@nebulae avatar
Vespa Rally 210
Why not post them up here?
I've done the conversion myself - don't have any photos though.
@sfvsr avatar
a lambretta or two
@sfvsr avatar
a lambretta or two
As an FYI to those thinking about purchasing the modified P200 stator for installing on Femsa compatible cases: I don't advise the purchase of the SIP modified stator. I've purchased two and both were damaged by whomever did the modification. The mill/lathe cut into the ignition coil and ruined it.
[ Time: 0.0090s ][ Queries: 3 (0.0026s) ][ live ][ 343 ][ ThingOne ]
