@keaton85 avatar
Stella 2T, P200, Rally 180 Euro
@keaton85 avatar
I have to port match the case and smooth out the ports on a new kit. Just wondering what you guys would recommend for bits?
@joep avatar
05 PX, 80P200, 63Li150, to many others
@joep avatar
@keaton85 avatar
@keaton85 avatar
Thanks! I have a ton of the sand paper style, just did not have any reference to what bit to use to cut down metal at a good speed without going through a ton of bits.
@mighty_triceratops avatar
'79 P200
'79 P200
Good thread! Also, I'm getting a better one here soon. What is the sweet spot for a new machine, considering price and quality. Vader, I'm looking to you because I've seen you blow through a few of em.
@mr10 avatar
150 GLx, Rally 200
@mr10 avatar
150 GLx, Rally 200
I find the cutter mentioned to dig in quite fast, making it less handy for larger surfaces.
I prefer a bit beefier egg shaped cutter, which allows for rounding corners (e.g. the bottom of a transferport) easier.
Also the click-on polisher is quite nice.
@t5bitza69 avatar
T5s
@t5bitza69 avatar
T5s
turnout
heavy night .... try this .....
^^^^^^ will this take care of that hemorrhoid problem?
@keaton85 avatar
@keaton85 avatar
And there goes the topic...
Sorry, could not resist a follow up to Bitsa.
@t5bitza69 avatar
T5s
@t5bitza69 avatar
T5s
fingerlongerer
tis ok keaton ..... sure theyll do one thatll get right in there n un stick you
@scooterraton avatar
2 - Many
2 - Many
I honed my skills working on antique clocks so learning precision control was critical. I think that how the tool is used is just as important as to what bur is used.
I like the CT egg shaped also for removing lots of material and for having control. I also like the diamond needle burs for fine detail work.
I've burned through a few dremels. Right now my main go to is a black and decker with flex shaft. A flywheel holder tool is perfect for hanging the unit when using the flex shaft.
For polishing I like the bullet tips and work down to polishing rouge.
Also remember that if it seems like your tool is loosing power or wearing out often all you need to do is replace the motor brushes.
[ Time: 0.0101s ][ Queries: 4 (0.0022s) ][ live ][ 343 ][ ThingOne ]
