Posts: 1574 Location: Minneapolis MN |
That's what i was told this morning when I had a set of City Grips fitted. So...how long are they "new"? Anyone know? 100 miles? 500?
'12 Kymco People GTi300, '06 Yamaha Morphous,'10 Vespa GTS300s
Posts: 380 Location: las cruces, nm |
Slippery
I think 50 to 75 miles is enough to wear off the mold release.
Karlu Las Cruces, NM |
Posts: 4755 Location: Hertford, North Carolina |
Grumpy Biker
Posts: 5729 Location: Sparks, Nevada, USA |
All new tires are a bit slippery when new. There is a bit of release compound left on them from the molding process. Only takes a few miles to wear it off. Of course the edges take a little longer since we don't spend much time on that part of the tire.
-Craig |
Peugeot Citystar 200i, Vespa PX 200
Posts: 798 Location: Finland |
Posts: 482 Location: Houston, Texas USA |
And if you use any of the tire "wet" treatments please be sure not to get it on any surface that contacts the road
Slippery when new hey?
My first thought was babies, but since you actually mean tyres........ You'll be fine. Honest. If you had brand new tyres with stickers on the track and deliberately run over painted lines in drizzle at 100mph, well then serves you right. But on the road, especially if it's dry, the issues are not anywhere near as bad as people make them out to be. In drizzly wet stuff, new tyres are a tiny bit slipperier, but really it's not worth stressing over. Enjoy the ride! 8) PS: new babies really are slippery little suckers........ |
Posts: 23333 Location: Harriman, Tennessee, Tn |
caschnd1 wrote: Of course the edges take a little longer since we don't spend much time on that part of the tire. -Craig |
RIP
I had an encounter with a wet street,years of oil and suntan oil on a road, a few miles after i changed out my front tire. There's something to the new tire and wet road thing. Not a good feeling to hit the brakes and still keep going. That said i've never had a problem on dry roads. Am cautious whenever i get a new tire on tho.
Grumpy Biker
old as dirt wrote: caschnd1 wrote: Of course the edges take a little longer since we don't spend much time on that part of the tire. -Craig |
Fittend with those City Grip for almost 7000 km by now on my GTS 300, and still find them slippery, especially during rain or on new road surfaces.
2007 Vespa GT200 - 2010 Vespa GTS 300 Super - 2013 Piaggio BV 350
Posts: 863 Location: Ventura County, CA |
franwar wrote: Fittend with those City Grip for almost 7000 km by now on my GTS 300, and still find them slippery, especially during rain or on new road surfaces. |
Wanted
Posts: 5485 Location: Jacksonville, Florida. Weaverville, NC |
Unless you are braking very hard or cornering very fast, I don't think you have to be concerned about riding with new tires. I have never had an issue with them, and I ride harder and faster than anyone I regularly ride with.
I have put on at least four new front tires and seven or eight new rear tires and never changed my riding style. |
I had quite an exciting encounter with new tires on my bicycle some years ago. A new pair of Michelin Pro 2 Race tires were installed, which were one step down in grip from the Pro 3 Race silicon rubber tires I been running in the summer. I did notice that the Pro 2 tires had a shiny coating. There was one last chance to test them outdoors as my wife was leaving for work in Switzerland that noon, so I would be the only caregiver for our then tiny boy.
There had been a rainstorm for the first time in weeks, but the road was quite *nearly* dry. I miss-read the side label and overinflated them. I was in cleats. Although I was being cautious and slowed greatly, I felt confident enough to take the first ever turn with the inside pedal down. I went down really hard (no memory) and I woke up to a motorist wondering if I was alive. My helmet's styrofoam liner collapsed to one third its normal thickness and was broken into 7 pieces. Though there were no broken bones it took months to recover from that fall. At that point I think I had safely ridden around 50,000 miles, largely at good speed, but that did not protect me from a perfect storm of mistakes and conditions. Ugh. I think that if any one of the mentioned conditions were removed it would not have happened. |
Posts: 45964 Location: Pleasant Hill, CA |
Motorcycle tyres do NOT have release agent on them - they are smooth when new because the moulds are smooth. Yes, you'll get better grip when they're roughed up a little (takes a few miles) and when they're warmed up (takes the same few miles). By the time a new tyre is warmed up, it's about as grippy as it'll ever get.
Always let your tyres warm up before 'testing' them to their full extent, this applies to every ride, not just when tyres are new. |
GTS 300ABS, Buddy Kick 125
Posts: 13559 Location: Oregon City, OR |
judy wrote: I had an encounter with a wet street, years of ......... suntan oil on a road, a few miles after i changed out my front tire. |
Piaggio BV250
Posts: 2429 Location: Historic Route 66 in Oklahoma |
Piaggio BV250
Route 66 Lawdog wrote: old as dirt wrote: caschnd1 wrote: Of course the edges take a little longer since we don't spend much time on that part of the tire. -Craig |
Posts: 2610 Location: Midway, Kentucky |
jimc wrote: Motorcycle tyres do NOT have release agent on them - they are smooth when new because the moulds are smooth. Yes, you'll get better grip when they're roughed up a little (takes a few miles) and when they're warmed up (takes the same few miles). By the time a new tyre is warmed up, it's about as grippy as it'll ever get. Always let your tyres warm up before 'testing' them to their full extent, this applies to every ride, not just when tyres are new. |
Montebianco Primavera, Subaru turbo with Vespa trans
Posts: 178 Location: central coast, ca |
