@69dudes avatar
Vespa GTV 250, ET2
@69dudes avatar
Vespa GTV 250, ET2
Does any know if you can fit an Akropovic exhaust in conjunction with side crash bars? I have a GTV 250. I don't want to order anything only for it not to fit due to the sticky outy bars near my stock exhaust. Any ideas? Thanks in advance.
@shebalba avatar
@shebalba avatar
What crash bars do you have? Can you post a pic of your current set up?
I have the Akra on my GTS, and it cleaned up that area quite a bit (in addition to dropping about 8 lbs), but I do not have crash bars. I ride with folks that have crash bars and after market exhaust (but not the Akra), so my initial thought is there should be no issue.
Someone with your exact set-up + Akra should be along with a definitive.
You'll love the exhaust.
@69dudes avatar
Vespa GTV 250, ET2
@69dudes avatar
Vespa GTV 250, ET2
Thanks. Here is a pic. I was looking into the Akra one as it seems to have good reviews on here, so fingers crossed it will still fit.
@shebalba avatar
@shebalba avatar
Check out this link and scroll down to the post by SoulSurferr
Crash bars
The bars might be slightly different, but you can see that they work with the Akra.
@69dudes avatar
Vespa GTV 250, ET2
@69dudes avatar
Vespa GTV 250, ET2
Oh crap. Just realised it's the wrong side of the scoot and I don't have one of t'other side. Hopefully someone will see the bars and know.
@69dudes avatar
Vespa GTV 250, ET2
@69dudes avatar
Vespa GTV 250, ET2
Crash bars
Thanks. Lots of info on those threads.
@shebalba avatar
@shebalba avatar
No Problem. Sometimes I find that a Google search for the scooter topic I'm interested in will bring up the exact Modern Vespa thread(s) I'm looking for better then the MV topic search function.
Keep us updated on your exhaust upgrade and post photos when you completed the install.
@69dudes avatar
Vespa GTV 250, ET2
@69dudes avatar
Vespa GTV 250, ET2
It was a google search that brought me to MV and I instantly joined as it's a very informative and friendly community. I have added a few more bits to the scoot since that photo, so one the exhaust is added I'll upload pics. Thanks again.
@brown_beret7 avatar
1975 Vespa GTR 125, 1976 Vespa V90 (Resto), 2001 Vespa ET4 125 (Sold), 2009 Vespa GTS300 Super
If those bars don't drop any lower than the bottom of the side panels, you should be fine with an Akra, which sits as low or lower than the OEM exhaust. Here's a pic I found with bars fitted that look even lower than yours...
@69dudes avatar
Vespa GTV 250, ET2
@69dudes avatar
Vespa GTV 250, ET2
That's awesome. Many thanks. Akra it is.
[ Time: 0.0122s ][ Queries: 6 (0.0033s) ][ live ][ 343 ][ ThingOne ]
