My bike fell over on the right side when covered and parked for the winter. I discovered that one of the feet was resting off the patio stones and on the cold ground which slowly gave away.
I put it back up on solid footing and left it till now when it's warm enough to ride.
What I discovered are the following symptoms:
What's working: horn, headlight and brake lights only with left brake lever.
What's not working: running lights, brake lights and start with right lever, instrument lights, turn signals.
The fuses are all good in the two block locations.
There is also a new loose rattling sound from under the top steering panel when the bike is idling.
It starts and runs normal. No body damage seen.
I just had the bike fully serviced before parking it covered outside for the winter (no garage) and I don't want to have to take it back again.
Dennis
