mp3 400 lt
mp3 400 lt
Where do you mount a camera on a mp3? I tried this:
It's a bit crowdy inside the helmed and it looks foolish , but it works for me.
@fentonfred avatar
2009 Piaggio MP3 250
@fentonfred avatar
Re: videocamera mounting
My GoPro came with two mounts, so I put one on top of my helmet and one on the dashboard of the bike so the camera points down at an angle, but the videos still look fine.
@stickyfrog avatar
Moderatus Rana
MP3 250 and 2 MP3 500s
Moderatus Rana
@stickyfrog avatar
So there really are windmills in Holland.
It looks like it would be a bit cramped for me but if it works for you then cool. You could also use the built in mic to do commentary while you ride.
Nice fabrication.
@loulouclub avatar
mp3 lt 400
@loulouclub avatar
mp3 lt 400
I also think its a very interesting approach. but if you fall face forward with your helmet, it can be dangerous to the face ! , a rather preferred external fixation, for your safety ! there are cheap adhesive attachments to the gopro.
mp3 400 lt
mp3 400 lt
@ stickyfrog:You like windmills ? You can watch for 5 min to this windmill tour . Don't fall asleep.
@hollybry avatar
2007 Piaggio MP3 250 (sold) and 2009 MP3 400 (sold) 2011 CanAm Spyder RSS
@hollybry avatar
Mine is mounted on the brake reservoir cover.
The cover does need some reinforcement or else the camera will pull it off.
My solution was to zip tie the cover down.
@fentonfred avatar
@fentonfred avatar
That works too, I have my GPS mounted the same way.
@hadantor avatar
Piaggio MP3 400
@hadantor avatar
Piaggio MP3 400
Before when I had the bars from the 400 and tupperware, I drilled a couple of holes in the plastic, mounted the camera to its flat base using 3M sticky pad, ran 1 bolt through the flat base, and used two more holes and zip tie.
(a little paranoid)
Now that I have the bars of a 500 on my 400. Clamp to the bars.
I seriously hated the plastic around the 400s bars.
@klaborde avatar
@klaborde avatar
This is how I mount mine...
Works Great.
Keith,
Marietta, GA
@loulouclub avatar
mp3 lt 400
@loulouclub avatar
mp3 lt 400
if it's possible, I am absolutely happy to see a video of you
@loulouclub avatar
mp3 lt 400
@loulouclub avatar
mp3 lt 400
there is also this possibility
its easy to mount a camera, goto the 2 min mark and you can see my mounting method
http://www.youtube.com/watch?feature=player_embedded&v=FZGeu0lDIrA
@loulouclub avatar
mp3 lt 400
@loulouclub avatar
mp3 lt 400
Clap emoticon I love bravo !. did a test with a stick and your video camera after , and after change the angle of view , you continue on with molten camera video editing, its can be good!
@stickyfrog avatar
Moderatus Rana
Moderatus Rana
@stickyfrog avatar
Or if you really want to get cool and make it look like you have a film crew try this. Originally posted in NSM by astromags. Built by guys from New Orleans Scooter Coop.
How it was done:
Be careful if you lane split.
@loulouclub avatar
mp3 lt 400
@loulouclub avatar
mp3 lt 400
How it was done:
wow! thank you so much stickyfrog for sharing, I am very interested for the system!
can be I'll do, but smaller .
@stickyfrog avatar
Moderatus Rana
Moderatus Rana
@stickyfrog avatar
Yeah I thought it was really cool when I first saw it too. I may try it for the fall gathering.
@loulouclub avatar
mp3 lt 400
@loulouclub avatar
mp3 lt 400
I think its a good idea to system, but the stick and a little too big, that there are a risk of destroy the gopro , with the cars or the trucks .
I began to study the problem , and I think, with the stick 70 cm of length its very well , compensated with a against -weight .
@stickyfrog avatar
Moderatus Rana
Moderatus Rana
@stickyfrog avatar
Will be interested in your results LLC. I was thinking about mounting on the top case. I know that won't get 360 degree shots because I will be in the way but it may give some cool perspectives.
@loulouclub avatar
mp3 lt 400
@loulouclub avatar
mp3 lt 400
ok, I think about all that, I do not promise a Imediat result, but with a little patience...
@hadantor avatar
Piaggio MP3 400
@hadantor avatar
Piaggio MP3 400
Rhino Cameras make this kind of mount. You can see it in some of the shots in this vid.
loulouclub, the music in the vid you posted was catchy in that 80's hairband kind of way. It made me nostalgic for the 80's
@loulouclub avatar
mp3 lt 400
@loulouclub avatar
mp3 lt 400
[quote="Hadantor"]Rhino Cameras make this kind of mount. You can see it in some of the shots in this vid.
Laughing emoticon lol if you love it, you see the older style of music . another of video more french in paris
@hadantor avatar
Piaggio MP3 400
@hadantor avatar
Piaggio MP3 400
Merci beaucoup loulouclub, tres impressionnant. I enjoy swing music, and to share my love, here is the Squirrel Nut Zippers
I like the video too.
@loulouclub avatar
mp3 lt 400
@loulouclub avatar
mp3 lt 400
Here, finally one of my videos showing all angles of shooting ,that I tested .
Piaggio MP3 LT 500 Sports 2013
my setup - happy with it so far
@loulouclub avatar
mp3 lt 400
@loulouclub avatar
mp3 lt 400
Hi stickyfrog
As promised, I present to everyone, results research of my prototype of the " rotor gopro " , it not finish but it advance , .... to be continued
" LLC "
@stickyfrog avatar
Moderatus Rana
Moderatus Rana
@stickyfrog avatar
loulouclub wrote:
Hi stickyfrog
" LLC "
Looks good LLC.
@hadantor avatar
Piaggio MP3 400
@hadantor avatar
Piaggio MP3 400
So one thing that has been bothering me. How do you keep that from hitting yourself in the head.
IM JUST JOKING!
@loulouclub avatar
mp3 lt 400
@loulouclub avatar
mp3 lt 400
stickyfrog wrote:
loulouclub wrote:
Hi stickyfrog
" LLC "
Looks good LLC.
here's what it looks like since, I upgraded the prototype.
enjoy
@stickyfrog avatar
Moderatus Rana
Moderatus Rana
@stickyfrog avatar
A good result. Looks like you got the balance just right. I do think the camera needs to be a little further away. Maybe 10 to 20 cm might do it. Or does the gopro allow a change in zoom? May zoom out a bit.
I have a gopro but haven't messed the the setting much.
Overall though it looks good. Have you got a picture of the finished rig you used in the video?
@loulouclub avatar
mp3 lt 400
@loulouclub avatar
mp3 lt 400
Hi stickyfrog
yes I agree I improve the support of 30 cm , now I'm past has a total length of 1 meter! the platform and still improving...! she and provisional, but does its job well. LOL Laughing emoticon
[ Time: 0.0220s ][ Queries: 4 (0.0033s) ][ live ][ 343 ][ ThingOne ]
