2012 Vespa GTS 300 Super
Hello:
Just wondering whether someone could recommend a good setup for mounting an iPhone 5 on the, I suppose, mirror rod? I don't see any other place it could go!
Thanks in advance.
@ashbrook avatar
Vespa GTS Kymco AK550
@ashbrook avatar
Re: Best iPhone/Phone holder for a GTS300 Super?
GTS300Pgh wrote:
Hello:
Thanks in advance.
The search facility is your friend!
Check this discussion from a few days ago
iPhone mounting for Google maps directions
Yes, thank you. I wonder what this mount is called? Unfortunately I can't search for "black handlebar mount" - or maybe I can?
ashbrook wrote:
Originally I had this set up for my RAM mount
@ashbrook avatar
@ashbrook avatar
Also this if you want a start from scratch solution
Mounting an iphone on a 250 GTS step-by-step walk thru
@ashbrook avatar
@ashbrook avatar
It says on the picture its a RAM mount
I went and looked and I actually do have that mount in the pic. I also have a piece with a ball on one end and a rectangle plate with 4 bolts (came with my Zumo 660).
Ah, forget it. I don't even know what I'm asking at this point.
@ashbrook avatar
@ashbrook avatar
Don't give up. We will do our best to help. The Ram mount seems to be a good semi permanent solution if you want to use your mirror stem. You need to attach the bit with the ball to you scooter somehow. Have you a picture of your bits?
lol thanks. It's just been a bad day so far.
Here's what I have now.
Vespa 300 GTS SS
Vespa 300 GTS SS
Cell phone holder
I have found this ram mount to work great. I use Garmin mapping app.
that's awesome thanks! I'll order one.
@blackrod avatar
2005 GT200L
@blackrod avatar
2005 GT200L
Check out RAM Mounts. They are very durable. I have a RAM Mount for my Zumo 350 on the mirror stem of my GT200.
A friend of mine has the X-Grip RAM Mount with his iphone and is very pleased.
@united4sure avatar
LXV
@united4sure avatar
LXV
I'm using this for my iphone..
[ Time: 0.0100s ][ Queries: 4 (0.0038s) ][ live ][ 343 ][ ThingOne ]
