@bholinath avatar
Rally 200, SS 180, ET3
@bholinath avatar
Can i use a rear hub from late px200 on early Rally 200 or early P200 engine?
I have upgraded my driveshaft, gears, nut, crux, etc, etc to the late px gearbox.
Would it just be a matter of swapping the seals to suit the 30mm hub? Or are they quite different?
I have to buy a new hub for another Pinasco 225 engine im building and wondering what the differences are.
I just ordered a new hub for my '87 EFL engine and was a bit confused to say the least. I thought it was simply old PX/Rally (27mm) or EFL onwards (30mm). It appears that some time in the 90's, there was a revised EFL, which may or may not be the same as PX200/Disc/MY of later years.
My EFL has a sealed output shaft bearing with an inner oil seal. Thinking that I had the later/latest type, I was ready to buy the 30mm hub. However, my oil seal has the dimensions 27x42x10, which tells me that the shaft diameter and therefore hub type needs to be the 27mm type.
Am I correct, incorrect or just in a Vespa daze?
@sfvsr avatar
a lambretta or two
@sfvsr avatar
a lambretta or two
Yes. Just use the correct seal for the hub. The ID of the seal is what you need to match to hub. The OD of the seals are all the same.
@bholinath avatar
@bholinath avatar
So would any (late or early px/rally) hub would fit on any (late/early px) drive shaft, so long as you use the correct oil seal (and hub nut etc) ?
As im using the late type gearbox in early motor block, i would prefer to use the late type hub too, to help avoid any more potential 'rear hub nut coming loose' problems.
I just wanted to check the two hubs are identical (with exception to the 27mm or 30mm sealing face).
[ Time: 0.0083s ][ Queries: 3 (0.0015s) ][ live ][ 343 ][ ThingOne ]
