@nightwing avatar
Contributor
2007 LX 150 (memories)
Contributor
@nightwing avatar
As many of you know, I have been plagued with No Post Mode Specified advisories for over a year. I can post from work without issue, but at home, 99% of the time I can't get on.
I have tried many experiments over the months with mixed results. However, I believe I have found a solution, although I can't explain it.
I have found that if I go into Safe Mode in Firefox which will open the browser without any add-ons. Then, I usually can post and it will take on the first try.
The thing that baffles me is that if I manually go into my options and disable all the add-ons, it doesn't work...I still can't post.
So, I don't know what the difference is, but automatic Safe Mode works while manual Safe-Mode doesn't.
I am in automatic Safe Mode now and will attempt to post. I am open to all suggestions.
@der_blechfahrer avatar
Sounds like you have a hidden add-on, probably the kind that nobody really wants. The kind that will replace all banners with other advertising. I've seen those come with free software.
[ Time: 0.0084s ][ Queries: 3 (0.0025s) ][ live ][ 343 ][ ThingOne ]
