Firstly, sorry if this was asked before, but is there a way to change the temp digital read out from Cent to Faren, just like km to miles?
Thanks in advance.
Thanks in advance. |
Piaggio MP3-500 (Desert Camo), MP3-400 (Pinky), Genuine Scooter Hooligan, Genuine Scooter Buddy 50, Genuine Scooter Black Cat
Posts: 711 Location: New Orleans, LA |
Doing this from memory so bear with me:
Turn on the key while holding down the mode button on the right grip. The bike display will flash everything then settle on kilometers (K) vs miles (M) which you can switch back and forth using the mode button. You indicate you know how to do this. Set it to whichever unit of measure works for you. Then hold down either the clock button or set button up underneath the display. The unit of measure should change to "C" which you can switch to "F" using the mode button. Turn off the bike and the next time you turn it on it should read in Farenheit. If I did not remember this correctly , hopefully somebody else will correct me. |
Quote: Press and hold the "MODE" «S» button for at least 3 seconds and at the same time turn the ignition key to "on". The icons "kmi" and "°E" will start flashing. "Kmi" represents the combination of "km" (kilometres) and "mi" (miles) "°E" represents the combination of "°C" (degrees Celsius) and "°F" (degrees Fahrenheit). By pushing the "MODE" «S» button for less than a second, the icons "km" and "mi" are selected sequentially. Push the "SET" button «M» to confirm the selection. Now the ambient temperature icon "°C" or "°F" starts flashing. By pushing the "MODE" «S» button for less than a second, the icons "°C" and "°F" are selected sequentially. Push the "SET" button «M» to confirm the selection. ⚠️ Last edited by ramblerdan on UTC; edited 1 time
Moderatus Rana
MP3 250 and 2 MP3 500s
Posts: 22736 Location: Nashville, Indiana |
Moderatus Rana
cummingsjc wrote: ramblerdan wrote: 500 owner's manual (U.S.), pages 13-14. |
stickyfrog wrote: cummingsjc wrote: ramblerdan wrote: 500 owner's manual (U.S.), pages 13-14. |
Moderatus Rana
Moderatus Rana
cummingsjc wrote: stickyfrog wrote: cummingsjc wrote: ramblerdan wrote: 500 owner's manual (U.S.), pages 13-14. |
stickyfrog wrote: cummingsjc wrote: stickyfrog wrote: cummingsjc wrote: ramblerdan wrote: 500 owner's manual (U.S.), pages 13-14. |
Moderatus Rana
Moderatus Rana
cummingsjc wrote: stickyfrog wrote: cummingsjc wrote: stickyfrog wrote: cummingsjc wrote: ramblerdan wrote: 500 owner's manual (U.S.), pages 13-14. |
stickyfrog wrote: cummingsjc wrote: stickyfrog wrote: cummingsjc wrote: stickyfrog wrote: cummingsjc wrote: ramblerdan wrote: 500 owner's manual (U.S.), pages 13-14. |
Moderatus Rana
Moderatus Rana
cummingsjc wrote: stickyfrog wrote: cummingsjc wrote: stickyfrog wrote: cummingsjc wrote: stickyfrog wrote: cummingsjc wrote: ramblerdan wrote: 500 owner's manual (U.S.), pages 13-14. |
