LX150
LX150
I have a quart of this stuff from when I did the brake on my wife's '83 Nighthawk 650. The opened bottle is about three years old. Do you guys think I can still use it?
Thanks in advance,
Harv
@stickyfrog avatar
Moderatus Rana
MP3 250 and 2 MP3 500s
Moderatus Rana
@stickyfrog avatar
If it is still clear then yes.
@midnight_rider avatar
09 GTS (sold) 2014 NC700XD
I would be weary...
@madison_sully avatar
I'd toss it. $4 for a new bottle not worth the possibility water vapors got in. I believe the fluid would still be clear even with some water; it's the rust and corrosion products that turn it dark.
07 LX50
07 LX50
12 seasons old +till its changed?
@kdude avatar
@kdude avatar
I concur ... moisture finds its way into brake fluid.
@modnrod avatar
Lambretta child
@modnrod avatar
Lambretta child
Rust and corrosion turn it dark.
Water vapour will turn it milky or opaque.
If it is clear, then you can use it.
I'm thinking that by the time the fluid turns milky, it no longer qualifies as DOT4.
A 1% water contamination of brake fluid drops the boiling point by 100 F.
Shelf Life. [Tip from Castrol RE: LMA Brake Fluid] Shelf life is no longer than 2 years, provided the oil has been stored in a cool, dry area, with no extreme fluctuating temperatures and the seal has remained intact.
Granted we aren't riding Gran Prix here, but for a few dollars more the risk isn't worth it to me.
@t5bitza69 avatar
T5s
@t5bitza69 avatar
T5s
fire too hot
no .... in easy terms itll have absorbed water from out there n water is more squishy than the oil so youd be better off leaving the old stuff in .....
if the bottle has enough room in it you could use it to bleed into n then take said oil for safe disposal
LX150
LX150
Thanks everyone.
I'll get a new bottle and use the other for old if I can.
Thanks again
Harv
Re: fire too hot
and the nay says say you don't help in technical stuff.
@t5bitza69 avatar
T5s
@t5bitza69 avatar
T5s
hate dot4
I does me best ....
dont spill any on ya scoot itll strip everything ........ cover everything ..... ive just done mine
[ Time: 0.0097s ][ Queries: 3 (0.0030s) ][ live ][ 343 ][ ThingOne ]
