Hi everyone, I mentioned this last year, but the problem is still ongoing.
I have a 2010 GTS125 Super ie. It had a fuel pump replaced under warranty before I bought it last year.
In warm weather, once the engine is turned off it won't start again for two hours, after which it's fine. The pump whirrs, the motor tries to start but then instantly cuts out. It's very frustrating because it means I can't use it for short trips, such as going to the shops.
I asked my local Vespa main dealer and they said it could be that the replacement fuel pump was also faulty. They contacted Piaggeo last September about the possibility of replacing it again, and still haven't heard anything.
Now the weather's warmed up, it's started doing it again. And I've had enough.
Here's my question: what it be better if I sourced a new fuel pump myself and got a garage to fit it. I think I've found a cheap, original pump but would it be a big/expensive job having it fitted?
