Here is what happened. My headlight and power in general has been flickering lately, so I started to investigate inside the headlight case/ horn cover area. As I wiggled the main harness going to the ignition (with the power on- key turned on) I heard clicking noise in the area of the lock...All went dead after that. No power when turning the key...not even CODE lamp blinking. I removed the ignition lock, cleaned the connections, re-connected the harness- nothing. Two wires out of 4 going into the lock have 12V on them according to my multimeter. Is it safe to assume, the internal ignition lock failure? (all fuses and grounds seem fine). Thanks. Dan
P.S. Are there any more fuses other than inside the glove compartment?
